Rockauto Canvas Top... HELP!
Wrenchtime
Post by Wrenchtime »
So... I'm new to these Fiats and convertibles. Picked out a sweet white canvas top from Rockauto since I was already ordering a ton of stuff.
Started to actually put it on the frame today and it's been a challenge. :?
Just wondering if anyone has installed one of these tops before? Any success? My primary beef is overall fitment and it seems like there's no way in hell that these wouldn't leak like a sieve! I can't seem to get the top pulled back far enough to install the two rivets in the chrome strip on the B pillar. At best, with the top locked down the canvas flap meets the chrome, but there is zero overlap. I could probably rivet it with the top pulled back, but I think it would be damaged when I forced it forward to latch it...
I'm about to cave and get a shop to do what they can, so any recommendations in the Detroit area are appreciated! :)
I also have a roll hoop which is complicating matters pretty significantly.
Any comments are greatly appreciated! Thanks! Was really hoping to be on the track Sunday...
124JOE
Re: Rockauto Canvas Top... HELP!
Post by 124JOE »
leak,yes most do
also are you sure you bought one for a 72?
as the top bow is just a bit different
does it fit to the back?
you may fashion a couple of filler peices and stich them in place then rivet them
v6spider
Post by v6spider »
Mine doesn't leak. Of course my top is a IAP high end sunfast top, but you should be able to install it providing it is cut for your frame and have it not leak. Use good seals.. Make sure you treat the canvas with some scotchguard.
Cheers!
Rob
http://www.v6spider.com
TX82FIAT
Post by TX82FIAT »
It does not leak by the standards it was built. Even the best top will have a little water makes its way in the Spider using one of the pressure washer or drive through car washes. The Rock Auto top, assuming you ordered by year and they know the differences in the header bow. Who is the manufacturer?
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
georgeramos
Post by georgeramos »
Rock auto has tops? .if properly installed and the proper year they shouldn't leak.
