I mean that you could swap an 85 mph speedometer out for a 140 mph and technically it should read the same no matter what the speedometer gear drive it. According to a guy I know.azruss wrote:the speedo is not clairvoyant. It only responds to how fast the cable is spinning. By this logic, the speedo drive would have to be matched to the rear end ratio.
But if you swap axles you need the speedometer gear that is matched for it. There is a chart somewhere that tells the ratios based on what spot of paint was placed on them (red, yellow, white). Probably long since worn off.
What's weird is I have an axle from a 1981 model (speedometer from the same car I am using) that should be a 3.9:1 but the paint marks on it says it's something else (like 4.3:1). They look factory like it's been painted using a stencil, not from one of those yellow paint markers hand painted by a junkyard.
I've also heard you cannot use a 3.5:1 speedometer gear drive from an automatic if you install a 3.5:1 axle in a Spider because the gear drive turns backwards. On the other hand it's a totally different transmission (GM) so I wouldn't think it would fit a SEAT/FIAT transmission anyway.
I've got a 3.5:1 Brava rear axle I've love to drop in my Spider but the trailing arm mounts are diagonally which would require some cutting and welding and I don't know if the drive shafts are correct length. Someone told me you had to use the rear end shaft from an automatic Spider which I don't have.
Also the Brava has rear drums so I don't know if the disc hardware could be swapped over. Sounds like allot of trouble to me but would be much nicer at highway speeds.
