Brake bleeding
- Your car is a: 1981 Fiat 2000
Brake bleeding
1981 2000. What is the brake bleeding sequence on this model ? Should the rear end be jacked higher than the front of the car? nitrate
- toplessexpat
- Your car is a: 1976 Spider 1800
Re: Brake bleeding
You need to raise the car by the rear axle so the compensator doesn't undo your good work.
I actually bleed with the car on the ground.
Start with rear passenger corner, then rear driver, then passenger, then driver.
A
A
Re: Brake bleeding
Thanks Houston. Appreciate that. RB
- lglade
Re: Brake bleeding
Conventional wisdom is to start at the caliper furthest away from the master cylinder and then move to the next furthest away and so on. I'm not sure that it really matters where you start, but this sequence works so I keep doing mine that way as well. I bleed mine on the ground too (just like TOPLESSEXPAT), and with a helper you can bleed the whole system in about fifteen minutes.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
2015 Subaru Outback
2017 Ford Focus RS
- DaveMarcotte
- Patron 2021
- Your car is a: Fiat Spider 1977
Re: Brake bleeding
do yourself a favor. Invest in a vacuum pump Work great and dont need a helper
Dave From Ottawa, Canada
https://goo.gl/photos/wm7Yzxf1KoB1nwYJ8
Re: Brake bleeding
Vacuum pump works better than a helper. You don't have to share the beer afterwards either. Win, win!
Re: Brake bleeding
Thanks guys. Just one thing, do you jack rear of the BODY up or do you jack it up under the REAR AXEL?
- aj81spider
Re: Brake bleeding
Axle. If you jack the body the suspension will drop and the compensator will shut off flow of brake fluid to the rear brakes.
A.J.
2006 Corvette
2006 Corvette
- Odoyle
- Your car is a: 1983 Pinafarina Spider
Re: Brake bleeding
Place your jack (with a block of wood) under rear axle and lift from there. Also, I highly recommend you place jack stands under the axle while your working there. As long as the rear axle is elevated, you should be able to bleed the rear brakes.Nitrate wrote:Thanks guys. Just one thing, do you jack rear of the BODY up or do you jack it up under the REAR AXEL?
Re: Brake bleeding
Just to be clear, put the block off wood at the differential and jack it from the differential.
Re: Brake bleeding
Thanks everyone for your help. RB
Re: Brake bleeding
An alternative to a wood block: drill a 7/8 hole in the center of a hockey puck. Protects the drain plug, cushions and grabs the diff. They also fit nicelyinto the center of an HF jack pad, making a nice surface for lifting. I use an undrilled puck for the front.
+++1 on everthing above.
Neil
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
Madison, WI
72 FIAT 124 Spider
