Noise from Pass. Rear, when making turns, differential?
Hey guys I have noticed the 1971 Spider makes a bit of noise when making turns, sounds like passenger side rear tire. It also feels like it kind of hops on that side slightly. I was wondering if I should start by changing the diff. fluid or does this sound like a symptom of something else? Any info would be appreciated. Thanks.
- RoyBatty
Re: Noise from Pass. Rear, when making turns, differential?
Make sure your exhaust is not able to contact your driveshaft.
Other than that, it almost sounds like a broken tooth in the differential side or spider gears.
- focodave
Also, make sure it isn't something easy like the wheel lug nuts not being tight.
I would also check the wheel bearing and/or brake caliper on the offending side, as well.
Certainly you want the proper amount of gear lube in the diff, but topping it off and/or changing it will not magically fix the problem.
1970 MGB GT (my other hobby)
- seabeelt
- Patron 2019
Check where the exhaust pipe comes down near the pan hard rod. Mine hits the rod occasionally ( actually more than occasionally) and was driving me nuts as I thought sure I had a bad rear wheel bearing or something worse. Now that I know what it is I will fix it next time I put the car on jack stands to change fluids. I'm sure it will involve bleeding knuckles and swear words in order to shift that section of the exhaust about a 1/2 in to the rear
- BoHejlskov
- Your car is a: 1984 Pininfarina red with tan interior.
I vote for wheel bearing. Check if the wheel is a little loose when slightly off the ground.
Bo, driving an '85 Pinin in the south of Sweden
- v6spider
Sounds like spider gears in the differential to me.. If the noise only occurs in the turns then that's just the gears. If it is a constant noise then rear wheel bearings or brakes.. Providing the exhaust is not rubbing on the differential.
Cheers!
Rob
Cheers!
Rob
http://www.v6spider.com
