front spoiler
brackie1
front spoiler
Post by brackie1 »
Just bought a front spolier from Mark. I live in North Carolina got it in 3 days. Super service. Anyway I bought for cosmetics, but after getting it on I realize it actually reduced my engine temp. It actually scoops up the air and throws it into the engine compartment. Never thought of that before.I highly rrecommend it.
Gene
North Carolina
azruss
Re: front spoiler
Post by azruss »
You will also notice that it will keep the nose down at high speeds. It purpose is to take the incoming air and direct it around the side of the car rather than underneath where it lifts the car. A side effect is that air dams in front of the radiator creating a high pressure area that forces more air thru the radiator. It should also make your fuel economy a little worse.
Re: front spoiler
Is there a minimum speed where this begins to have any noticeable effect?
81SPIDERMATT
Re: front spoiler
Post by 81SPIDERMATT »
RRoller123 wrote:Is there a minimum speed where this begins to have any noticeable effect?
cooling and fuel consumption are noticed (for me) around 35 and up .... keeping the nose stuck to the road is a pretty high speed event .... I wanna say I noticed that part at around 65 and above ... really big "noticeable" difference as approaching speeds that will get you "big" tickets in most states
edit ... and watch out for those parking stump things .... they sneak up on you quick ... ask me how I know
Re: front spoiler
Makes sense about holding the nose down, the front end of the Spider without a spoiler is a lift foil shape for sure.
azruss
Re: front spoiler
Post by azruss »
the first version of my current air dam was built in the early 80s. I would notice the car getting "lighter" (determined by road feel and less effort in steering) up to about 40. At that point, the car would begin to feel "heavier" and at 55 mph had the same road feel as the car did at 30. As I increased speed, the car remained with the 30 mph road feel. Another thing i noticed was when i drove over a plastic bag or some other air borne debris, it stayed under the car 3 times longer than without the air dam.
brackie1
Re: front spoiler
Post by brackie1 »
About the speed thing. I never get it over 70. Have not felt any difference. Don't really care about fuel economy. My main concern was the air into the engine and the look. I guess all of those other attributes are great.
Gene
North Carolina
DanD
Re: front spoiler
Post by DanD »
How about a picture ? 8)
brackie1
Re: front spoiler
Post by brackie1 »
here is a pic as you requested. My is bkack and the spoiler is black so I had to lighten the pic up a little so it could be seen.
Gene
North Carolina
toplessexpat
Re: front spoiler
Post by toplessexpat »
I like what you've done with the bumperettes there... and are those TJ turn signals?
www.mirafiori.com
brackie1
Re: front spoiler
Post by brackie1 »
Bumperets are from a 67 Plymouth Fury. I did the same on the rear using MGB bumperets. The turn signals are from a jeep wrangler not sure what year bought them on amazon. They don't fit perfectly because they are flat and the fender is curved, but I think looks good from a distance. :D
Gene
North Carolina
toplessexpat
Re: front spoiler
Yep - I've got a pair of the same turn signals which I'm probably going to fit on my FI. I've got VW signals on my 1800 which actually work pretty well (as they're slightly curved). I'm thinking some judicious heat gun application may work!
A
www.mirafiori.com
brackie1
Re: front spoiler
Post by brackie1 »
I would love to find some kind of trim ring to go around them.
Gene
North Carolina
WYSpider
Re: front spoiler
Post by WYSpider »
Nice bumpers. :)
toplessexpat
Re: front spoiler
brackie1 wrote:I would love to find some kind of trim ring to go around them.
Perhaps a rubber gasket - it should compress a little more in the center to give a more finished look ? (not that it doesn't look pretty nice right now!)
www.mirafiori.com
