So I sent the Spider off to finishing school.......I waved BYE BYE as the painter drove away with the old girl.
At last, some much needed body work. Almost every panel had a small dent or ding and the body shop is making the "rough">>>>"smooth"
While the Spider gets a face lift, I will be rebuilding/renewing the mechanicals. I just finished cleaning up the steering box and could use a gasket/seal kit. I found the input and output shaft seals on eBay, but have not found a gasket for the top plate. I saw that the front plate has nylon shims so I bagged and tagged them for reuse. Anybody know where I could find the top gasket? I was surprised that those nylon shims provide a good seal without any gasket sealer. The Pittman arm is really difficult to remove using the removal tool........maybe a torch is in order.
Any reassembly advice is welcome, as this will be my first tear down and reassembly of a Spider. Restoration is a very overused term, but I think this is pretty close to a "body-off" or a "ground up" restoration.
My "Goomba" Tony from X-Web was here to help with some of the teardown. After the working on the car, we all sat down to big bowl of Rigatoni and meatballs.......good friends and good food,....it just doesn't get any better.
As soon as the bodywork and paint are done I can reassemble the car, and then send the motor out to Mark Allison for a much needed freshen-up.
Enjoy the photos and please wish me luck....
