![Very Happy :D](./images/smilies/icon_biggrin.gif)
A few outstanding/nagging issues. If anyone has any advice it would be much appreciated.
1. Oil leak at filter
I replaced the oil and filter. I cleaned everything well and hand tightened the filter. No leaks but once I started the engine some fresh oil came out slowly. Should I just try tightening it more? Hopefully I still have my oil filter wrench.
2. Vapor at top of radiator when hot
Engine temp was great and fan came on/off at correct times. Just noticed a wisp of vapor from the top passenger side of the rad. Do I need a new rad? Is there some fluid I can try out to block the leak?
3. Exhaust leak (I think that's what it is... not sure) at exhaust header near front of engine (near radiator)
I guess I'll try to torque down those bolts again. Got a new gasket there and cleaned after well before. I'll probably try to clean up the area 1st and ensure it's nothing else. Doesn't smell weird (ie. like coolant).
I didn't do timing yet but engine runs well. Can I time by ear or do I need a timing light? And what's the procedure? Loosen distributor mounting bolt a bit (engine off), twist one way and time again. Or can I do this with engine running and just loosen a bit and twist until engine runs best?
