Thought I'd take the time to give you some information on replacing 124 stub axles with 125 items, in addition to WHOA brakes.
I haver a 124 spider with WHOA brakes. They're great. Easy installation and great performance. They've been on the car for a couple of years now. With the Fiat Nationals coming up, I though I would upgrade the front end to thicker 125 stub axles to handle the greater loads of sprinting and also lower the car.
So I've sourced a set of 125 units and given them an overhaul (Thanks Sideways), jacked the car up and ripped apart the front suspension. Installed all the new equipment. Eveything was going well until it came time to mounting the caliper. Guess what, it didn't fit. Wilwoods, being fixed calipers, need to align to the rotor. The 125 stb axles being wider, increases the gap between the rotor and the caliper mount. This isn't a problem with standard calipers as the offset is taken up by the floating caliper.
So I could put a spacer between the caliper carrier and the stub axle to take up the slack. This won't work as the 125 hub is a larger diameter than the 124 unit and the carrier will snag on the hub.
So in summary. If you've got Whoa brakes to fit a 124, you can't fit 125 stub axles. Refer photos
Here are some dimensions that I have measured between 124 and 124 stb axles. All measurements are in mm
.............................................124..........125
Hub Dia....................................65...........67
Spindle centre to lower ball joint.......66...........72........lower the car by 6mm
Stub axle height........................144.4.......162.2......this raises the upper control arm closer to the bump stop
Larger journal............................26.16.......31.78
Small journal.............................19............19........Same axle bolt and dust cap
Disk to carrier face.......................63............67.30...misalignment dimension
Disk to carrier............................1.8...........6.5......misalignment dimension
..............Whoa carrier on a 124.......................Whoa carrier on a 125
