oil cooler installatiom
scampbel98
Your car is a: 1980 Fiat 124 carb
Contact:
Post by scampbel98 »
Please share any pics of oil cooler installs. I'm undertaking installation of a 7"x12" unit and would appreciate looking at other approaches
coise
Re: oil cooler installatiom
Post by coise »
Here is my set up.
The cooler is on the inferior grill but not touching it.
scampbel98
Contact:
Thanks coise,
That's about what I was thinking of doing. That looks like a transmission filter. Did you just punch through the fins for that?
coise
Post by coise »
Yes, it´s a transmission oïl cooler but it works fine. Also, yes I went through the fines with some ''fan to radiator'' type attachement.
For the hoses fitting it´s just a plate that you can add between the oïl filter and the original bracket.
I don't know if I´m clear enought but ...
vandor
Post by vandor »
Dang, I really hate to see barbed fittings and clamp-on hoses on an engine oil circuit! I'd have hoses with AN fittings made. Yes, it costs more. For a reason :-)
spiderrey
Post by spiderrey »
I have an oil cooler similar to the one on the GTI. It cools with water.
vandor
Post by vandor »
Yes, those are neat because they heat the oil when it's cold, and cool it if it's too hot.
MrJD
Your car is a: Looking to ask questions about a 79 2.0
Post by MrJD »
So im curious: why an oil cooler? Any major reason other than potentially invreasing longevity?
Daniel
Post by Daniel »
MrJD wrote:So im curious: why an oil cooler? Any major reason other than potentially invreasing longevity?
It's not a necessary modification but to bring the oil temp down doesn't hurt, modern motor oils can handle high temps
no problem not like years ago they were more likely to break down under extreme conditions...
Jimb
Your car is a: 1985.5 Volumex
Post by Jimb »
An oil cooler is stock on the volumex
spiderrey
Post by spiderrey »
What type of cooler?
MrJD
Post by MrJD »
Jimb wrote:An oil cooler is stock on the volumex
I assume they are pumping oil through the SC to cool it (same with a turbocharged engine). On a NA engine... it looks nice and all... but? I think the money would be better spent on updating the cooling system of the engine.
Daniel
Post by Daniel »
You brought up a good point this would be added protection for the parts on a turbo or blower that really need
some.
paintdudeluke
Post by paintdudeluke »
Oil coolers really are a great idea on anything driven fairly hard. Oil can run over 300 degrees pretty easy if you're really leaning on it and a cooler keeps the viscosity up plus pulls heat out of your bearings etc. Higher viscosity equates to better pressure and flow to the top end. Watch how much steadier an oil pressure gauge reads when things are cool and then notice how the pressure drops on idle once it warms up. Cool oil is a real blessing.
lanciahf
Post by lanciahf »
Where did you get it?
spiderrey wrote:I have an oil cooler similar to the one on the GTI. It cools with water.
