I have not had a chance to check anything yet,but I did look and the control arms are new,
Does vicks sell the Russia kind
I will not buy shit from them again
Here what I'm going to do.
I need the rear springs changed being the height from the front and back is a 1 1/2 inch differnt,
So maybe in changing the rear,makin it the same height ,it will change the alignment! Then I will go from there
Any thoughts?
I just did some checking. From very rough measurements, if you put the left arm on the right side, and right arm on the left side, it will make the caster off by about 11 degrees. (arctan(2/10). On your sheet, it shows this being off about this amount. Also, with this amount of negative caster, it will be very hard to drive (no self-centering). This would also affect the camber.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
I just got a new passenger side upper and lower control arms at that time,I swap out the ball joints on the driver side.im going to talk to a guy Monday and see what he says about this
Here is what puzzles me. I got this alignment done long ago,after I installed the crossmember,and control arms,put new brakes in,then I got the seat rails in
Then finally I got to get alignment done,the guy told me that I'm better off getting the life time alignment just because I may have to tweak it now and then,so I did, now mind you this car had the springs cut, the alignment came back good at that time,the guy told me it was so close but can't get it to the specs,but that both sides where great and the tires would wear evenly,
Ok so in driving the car after I was happy but the steering was wierd,and plus it road rough, ok so my next thing was getting the front springs changed,well I did,and now it all messed up.
Now you know the rest,
here is a thought> since i did the new cross member there was a metal plate that goes in between the cross member and frame, would it matter what side that spacer went in? it on the driver side, should it be on the passenger side?
would that make a difference? thanks
as stated the passenger side is the problem side..... curious if you moved the plate to the passenger side would then you have a problem on the drivers side..... that plate is a way to push out the top of the arm (?????) ... which would solve your problem .. in theory ...
disclaimer..... just throwing darts... easy for me to say from my comfy computer chair .... the visual in my head seems like it might work... but again ... just guessing
your post and azruss are the first i have heard of a plate between the cross member and the frame....
Ok I got an look at the towers, here what I notice,driver side top where the drain plug is ,that's straight
Passenger side ,same area, look at the photo
Do you think this coud be the problem,
that is a very common problem. the car has been bottomed out hard at some point, that causes negative camber that cannot be adjusted out sometimes. the shock towers can be moved back into place and reinforced. but if you are not having any camber problems, you can just leave it alone too
son has 78 spider
BEEK wrote:that is a very common problem. the car has been bottomed out hard at some point, that causes negative camber that cannot be adjusted out sometimes. the shock towers can be moved back into place and reinforced. but if you are not having any camber problems, you can just leave it alone too
Ok great.the passenger side is negative ,tire rubs , How do you move them back?
I'm taking it to a shop today and see how it can be fixed, I hope it cheap .
Any suggestions
This has got to be why the alignment is off on the passenger side,
fiat218 wrote:Ok I got an look at the towers, here what I notice,driver side top where the drain plug is ,that's straight
that would do it.... good job... curious what the shop will say.... glad you found the problem
he pulled down the chassis , passenger side and the alignment changed, so he said to put the lower springs back in
well that aint going to happen. he said he cant do anything.
so i went to a body shop and he can pull that over he said. i do need some spec,if there such
It was sorta funny today,after all the news I got,I call my grease monkey ( mechanic) and told him that I got close 5000 already in this car,price,shipping etc, I said I might as well pull the engine and part out this hunk of , he said dont get hasty on this lol ,he a man that shakes his head every time he works on it so I thought he would be happy with me when I said I'd get rid of it . Maybe the fiats are growing on him
