Special TC Engine
- SLOSpider
Re: Special TC Engine
You can source the stock electronic distributor cheap and I wouldn't run anything less. I have a setup if you need. It needs the dist rebuilt and I would get a new module to be safe. Either way if it cost you $200.00 for a rebuilt dist and MSD coil with new module it will be one of the best money you could do.
I may have missed it but what was used for the attaching points of the front and back for the top cover?
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
- Special
- Your car is a: 1974 Special TC
I was thinking about getting Petronix kit - http://www.ebay.com/itm/330616388276?ss ... 1423.l2649 but had not decided yet.
And for the top cover I fabricated a bracket on the back , it is attached to the head bolt and the front mounts to the thermostat housing.
My Green Car aka Torrino - http://www.fiatspider.com/f15/viewtopic ... 30&t=30089
- SLOSpider
Ive ran all types and they all work great. The nice thing about the Fiat electronic is that it takes a standard GM $25.00 module at any autoparts store if for some reason it goes bad. But either style will be 100 percent better than the points.
1975 124 Spider
Hey man that engine looks Awesome, great job if only we could listen to engine recordings through this site,
maybe via U Tube:?:
maybe via U Tube:?:
- v6spider
Beautiful engine work...I agree a youtube video end would certainly be cool. I'll be posting one of my v6 when it's done and installed in my spider...
Rob
Rob
http://www.v6spider.com
- giuliot60
- Your car is a: 81 Fiat Turbo removed Spider
BTW, Where did you get the double wire (OEM looking) clamps special?
Giulio/Charlotte
When looking from the side at the carbs, I see you got a regulator! But what that piece in the center?,
- Special
Thank you very much guys !
Engine is not in the car yet , so no videos for now , sorry.
OEM looking clamps are ... OEM clamps , they came with the 2l engine.
If you are talking about this picture -
the thing in the middle is a Malpassi pressure regulator
unless you are talking about something else ?
what it do?
- Special
Adjusts fuel pressure.
So I got a 79 with dual carbs, I should prolly need that to adjust the fuel so it 3psi
Almost a shame to hide that in a car, it belongs in a museum!
Trey
How do you plan to lift the engine for installation? With the intake manifold installed you can't use a harness. I want to install manifold and carbs while the engine is out but I cant think of a way, maybe use head bolts.
- hayesbd
- Your car is a: 1973 Spider
Wow!
That is one amazing engine! Can you rebuild mine? Please!?
Brian
Brian
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
- Special
Yep . This one on some other one , just make sure it is for carbs and not for FI.fiat218 wrote:So I got a 79 with dual carbs, I should prolly need that to adjust the fuel so it 3psi
