A possible windscreen option?
wikkid
Post by wikkid »
I came across this web sitethat sells windscreens for serveral types of convertibles, including for MG and Miatas. So I emailed them for dimensions on their screens, to see if they could work in a Spider. I wonder if anyone has come across these and tried them. Pretty reasonable pricing, especially for the Miata.
kd1wo
Re: A possible windscreen option?
Post by kd1wo »
Please let us know of their response.
A lot of benefit for not a bad price! :)
redcars
Post by redcars »
I have one of thier Miata windscreens on my Spider and it fits nice. Anouther member worked with them to come up with backets to fit our spiders. I believe if you ask them that they now have them to sell with the windscreen. I made my own brackets as I wanted mine to be a quick change on and off without the use of tools
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
dantye
Your car is a: all gone
Post by dantye »
We love this one, if you have $20-$25 and are willing to make it: (no tools needed to install or remove)
http://fiatspider.com/f08/viewtopic.php ... d&start=45
Parts: 1 - 10' length - 1/2" I.D. Schedule 40 PVC conduit 2 - 90 deg. bends - 1/2" I.D. Schedule 40 PVC conduit 2 - in-line connectors - 1/2" I.D. Schedule 40 PVC conduit 4 - "T" connectors - 1/2" I.D.PVC water pipe 2 - 90 degree elbows - 1/2" I.D.PVC water pipe PVC cleaner & cement 1 - small roll, black fiberglass window screen - attach w/acetone based plastic cement. 5/8" I.D. rubber vacuum hose, cut for "t" inserts - attach using contact cement; Krylon flat black plastic spray paint.
Razooli
Your car is a: 1982 Fiat Spider 2000
Post by Razooli »
I have the Raceland Mazda Miata MX-5 V-Style Windblocker installed on mine. ~$50, very well made.
Lynn Shuler
1982 Spider 2000
Remember, this hobby is supposed to be your therapy, not the reason you need therapy.
donerehart
Your car is a: 1976 spider
Post by donerehart »
Lynn,
How did you mount the Mazda windscreen?
Don
76 Spider
St. Louis, MO
Razooli
Post by Razooli »
Don, I had replaced my rear seat with a plywood deck/speaker box so I mounted the screen on tubular chrome uprights
going thru the deck ...
You wouldn't want to go thru all that. Personally wanted a solution that was quickly removable, allowed the use of the boot without cutting a slit for a bracket and didn't attach to the headrests.
People have fashioned their own brackets that attach to various bolts on the convertible top frame, like this one.
It would be great if Raceland has developed their own brackets for the Spider.
Here's another one that I really like. I think it's a Raceland screen as well and it blocks air getting sucked in over the rear seat. I might give this one a try ...
During the winter (such as it is in SoCal) I put a piece of cardboard behind the rear seats to block the air flow below the windscreen from disrupting the heater air. This one should help that situation.
Lynn Shuler
1982 Spider 2000
JConnerly
Post by JConnerly »
Razooli: do you know which screen is mounted on the red car in the picture?
narfire
Post by narfire »
JConnerly wrote:Razooli: do you know which screen is mounted on the red car in the picture?
JIMB'S , On the back of his volumex. His design I believe. I saw it this past summer, very well thought out,professionally done.
Razooli
Post by Razooli »
Nope, sure don't. Raceland makes several like that, though, for SAAB and BMW. Don't know what the dimensions are.
Lynn Shuler
1982 Spider 2000
Jimb
Your car is a: 1985.5 Volumex
Post by Jimb »
Here's the link to my windscreen (the red car)
http://www.fiatspider.com/f08/viewtopic.php?f=3&t=19681
