short shift
short shift
just wondering if the original shifter is difficult to replace for the short shift. i seen mark has something on his web sight. just wondering if that just a handle or the whole unit?
- Wheel
- Your car is a: 1982 Fiat Spider
Re: short shift
Hi Jim,
I purchased the Shutt shifter from Mark. I do not have it fully installed yet as I need to make a new wood piece for the console. The leather boot chrome ring base is a bit bigger than the original shifter base, so you either have to modify the original wood console piece or make a new one.
The knob uses set screws to hold onto the inner shift shaft. The leather boot has a small chrome ring at the top that attaches to the bottom of the shift knob with another set of setscrews.
Here are some photos, hopefully they are fairly self explanatory. I am quite happy with the quality and I love the shorter shifts.
The photos are linked to photobucket and it always seems to take like 8 hours for the editing to come thru. The photos have been resized to be 640 wide. You will have to right-click and view image on each photo in case they appear be cut off. It will fix itself later.
John
John
1982 Fiat Spider
Re: short shift
did u just cut your handle shift rod off to the proper height and then put the knob on?Wheel wrote:Hi Jim,
John
- Wheel
Re: short shift
Nope, didn't have to cut it.
The inner shifter shaft is quite a bit shorter than the outer chrome shaft. You will see once you take the chrome outer shaft off. The inner shaft slides quite far inside the new shifter knob.
1982 Fiat Spider
Re: short shift
That rite I forgot how they looked, got it now, thanks, i am going to order one next weekWheel wrote:Nope, didn't have to cut it.
what the differnt between that michgan short shifter and what mark has
Re: short shift
I have a different knob now, that one in the pic was discontinued. We do have a few left that are brushed aluminum rather than black. Our kit includes the boot and retainer too.
- Wheel
Re: short shift
Can't comment much on the Michigan Short Shifter. I think it is basically a shortened outer shift shaft that slides over the inner shaft. I believe using this style allows you to keep your original shift knob and leather boot.
Here is a link to the Michigan Short Shifter:
http://webpages.charter.net/mbouse/Mich ... ctions.pdf
Here is a link to a version that AutoRicambi is selling. You will notice the setscrew holes to lock it to the inner shift shaft.
http://www.autoricambi.us/cgi/commerce. ... ey=TR5-690
Someone else who has experience with the Michigan Short Shifter might be able to confirm or add more information.
1982 Fiat Spider
Re: short shift
i like the brush aluminum, u said u have them yetSo Cal Mark wrote:I have a different knob now, that one in the pic was discontinued. We do have a few left that are brushed aluminum rather than black. Our kit includes the boot and retainer too.
Re: short shift
i will take the easy route, i think marks isWheel wrote:Can't comment much on the Michigan Short Shifter. I think it is basically a shortened outer shift shaft that slides over the inner shaft. I believe using this style allows you to keep your original shift knob and leather boot.
- kmead
Re: short shift
The Michigan Short Shifter and the one from Midwest may well be the same part and install in exactly the same way. I will check with the supplier.
The Michigan Short Shifter works with your existing knob and boot with no changes. It is a high quality part made of stainless steel.
The set up by Mark is very nice as well and really has a different look from standard, which is not to take anything from it, the boot is very nice and has a great looking retention ring.
Pick what you think will work best for you. I don't think there is a bad choice in any of the three.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
Re: short shift
thankskmead wrote:The Michigan Short Shifter and the one from Midwest may well be the same part and install in exactly the same way. I will check with the supplier.
Re: short shift
yes, we have two different brushed aluminum shift knobs now. One is just like the black one in the previous pics, the other is a more traditional round knob
