I have an 85 and want to replace the side mirror. The original side mirror scream 1980's. Everything I look at are power mirrors and I don't really want power mirrors. If I went with a power mirror and did not connect to power would I be able to adjust the mirror?
Thanks.
Side Mirrors
- Your car is a: 1985 Spider
Side Mirrors
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
Re: Side Mirrors
Confused.
If you have an 85, you have the through the vent window glass style of side mirror, like the red car in the header above. So that means there is a hole in that glass. Are you wanting to put a replacement mirror back in that same hole? Not sure there are any alternatives for that.
- 124JOE
Re: Side Mirrors
our mirrors screw on to the door
if you go with that style youll need to plug the hole in the glass
yes you can set a power mirror without power
Re: Side Mirrors
I was thinking of replacing the vent glass and mounting the mirror on the door.leftfield6 wrote:Confused.
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
- 124JOE
Re: Side Mirrors
i have a spare wing window and mirror
where are you at?
where are you at?
Re: Side Mirrors
Thanks for the offer, but I would need two.124JOE wrote:i have a spare wing window and mirror
where are you at?
I am thinking of trying the side mirror off a 1st gen Miata or Mini Cooper, or maybe even a Fiat 500. Any thoughts?
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
Re: Side Mirrors
Those are not bad, but I like the concept mirros better. I have seen the california mirrors listed for sale on ebay, but they look a little small. How do the sebring mirrors mount?Kent124 wrote:I've read that some people use Vitaloni Baby Tornado mirrors.
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
Re: Side Mirrors
http://www.ebay.com/itm/190584893261?ss ... 499wt_1185
I like these bullet type mirrors they're sharp and match the head lights, but youll need to do some grinding on the base if you mount it on a round surface.
Re: Side Mirrors
roanokeSpider wrote:http://www.ebay.com/itm/190584893261?ss ... 499wt_1185
I am hoping to go with a more updtaed look. I am about to order a pair of Miata mirrors just to see what I can do with them. They mount to the door and I suspect I would have to modify the base to fit on a spider. They all come powered, so I would need to be able to adjust the mirror without power. At some point I might attempt to connect to power. The more I look at the original mirrors, the more I do not like them. How hard is to take these off? Any ideas on what to do with the existing wings with a hole in the glass?
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
- 124JOE
Re: Side Mirrors
you could put stick on center cap emblems over the holes
