TIA!
Thanks. SInce I posted this, I've been reading about having to drill out the brackets. Mine are bolted, at least the ones on each end, and are pretty easy to access and loosen/tighten as I've done so when the old bushing tend to slip out. Am I missing something?engineerted wrote:No it is not under tension unless you jack up only one side, so jack up both sides and you will be fine.
