CARBS
- 124JOE
Re: CARBS
Re: CARBS
Wickhud pissah!
- 124JOE
Re: CARBS
at least they would stay clean on your table
- boogiedude
- Your car is a: 1978 spider 1800
Re: CARBS
That's a DCNF, not an IDF, just so you know
Re: CARBS
actually i notice that last nite, i was told there where idfs. i do hope they are still ok of a carb, or what. when i got them i just put them away and they stayed in the box, i just happen to look at the carb last nite and read it on there, KNOW WHAT YOUR BUYING I GUESS LOL
WELL are they still a good carb? i did read the idf's are better
http://www.ebay.com/itm/Weber-40-DCNF-3 ... 519ec93a20
can some one verify if this will fit the carbs i have, says it the same but being i had no clue on what the heck i bough ,i best need to have some one verify it, i want to get a set of cleaners like this and the top cage will be gold plated too
Re: CARBS
DCNFs work best on tranversley mounted motors (Think X/19, Lancia Zagatos, etc). The arrangement of the fuel pick up in the float bowl in a DCNF will cause fuel starvation in a moderate corner lateral g load, as the fuel pick up will become uncovered momentarily. This will cause a brief "stumble", which can be a bit hairy in the middle of the turn.
They will work fine on a 124 TC mounted longitudinally, other than the fuel starvation issue. I have run them on several motors (before I figured out why it would stumble in corners), and just learned to adapt my driving to limit the lateral g's in corners, or anticipate the stumble. I never did dyno a set of DCNFs against a set of IDFs, but I suspect the power output is nearly identical with both, and it certainly will be unnoticeable to the guy in the diver's seat.
The throttle linkage is a bit different, but not hard to solve. The jetting will be slightly different as the emulsion tubes work differently in a DCNF, but you will still need to do all the other things you need to do to really enjoy your twin carbs and get the most from them.
Of course, mine were gold plated.
Re: CARBS
well that kinda sucks now, starvation , i have all the linkage and stuff for it, now i wished i knew what i was buying live and learn
