Back seat delete
Ptoneill
Re: Back seat delete
Post by Ptoneill »
You guys are great....now I see where the clearance problem lies! I will trim the edges, my original plan was to cut the side panels to fit flush with the top, now I will cut the shelf to fit the side panels to allow the windows to fully retract.
I plan on painting the shelf with POR15, then the panel will be welded into place. I am hoping that it will provide some additional strength to the body. Prior to putting in the new carpet I will line the entire floor with hush mat or similar product to reduce noise.
Thanks again, it proves that the more eyes the better
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
baltobernie
Post by baltobernie »
I don't think you need be too concerned about adding structural rigidity in that location. The vertical "firewall" (forward portion of the trunk) is very thick, bead-rolled steel. With the speaker removed, you should be able to service the wiring that extends into the trunk. If you have any doubts, you could install a piece of conduit before welding the shelf in place.
Ptoneill
Post by Ptoneill »
I agree with you about the strength that was not the main reason, it is just an added benefit. There is plenty of room to run cables, although the only thing I may add is a sub woofer in the trunk.........
Hopefully we can get the deck trimmed and I can get new pictures up next week.
Stay Safe,
Pat
79spider
ptoneill@msn.com
