Engine Bay Gallery! Please add your own!
Re: Engine Bay Gallery! Please add your own!
72"
Currently, 1.8L engine (original was 1438cc):
Alvan, do u have the big bump or small with the duals
Flat hood (1970), so not much clearance to work with.
ok thanks
so a 69. 1608 with duals will work with a flat too
Russ, he doesn't have to test it, it's been proven on many other cars that even a freeflow filter won't help make up for the loss of breathing hot engine bay air. The difference is measurable on the dyno.azruss wrote:gritracing, i noticed you have a heatshield around your air filter. I assume that is to keep hot air from the exhaust away. is it effective. Have you run your car both ways to see if there is a performance difference. I'm thinking of doing the same and would like to know if it is worth the effort.
The only complication on a Spider 2000 is that you have to cut holes either next to the radiator or in the inner fender to get outside air.
- kmac33
- Your car is a: 1974 Spider
Try to guess which is before resto-mod and which is after.
Kevin McMullen
1980 Fiat Spider
2013 Subaru WRX
1980 Fiat Spider
2013 Subaru WRX
Some of you have some awesome looking engine pic's.
- blurple124
That is precisely what I was hoping for!Damini wrote:Some of you have some awesome looking engine pic's.
Charlie
1978 Fiat 124 Spider 1800 - Antonia
1997 Jeep Wrangler TJ Sport
- divace73
very noice kmac33, I have always wondered about the air pump in the exhaust??
Wouldn't putting more air in the exhaust be the same as measuring the co2 a distance from the exhaut pipe?
Cheers David
see my >>You tube channel<<
i plan on decking out the 69. engine and bay. getting the dual carbs gold plated
Neat story.fiat218 wrote:i plan on decking out the 69. engine and bay. getting the dual carbs gold plated
- 124ADDHE
Nice Pics!. The idea of injecting air into the exhaust just outside of the combustion chamber is to allow the still very hot and unburnt gasses to finish burning with the addition of oxygen, @ the end of the tailpipe the unburnt fuel is unable to combust due to the now cool temperature from the heat loss through the exhaust pipe.
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Our '81 spider and '72 coupe (when it had the FI system on it).
IMG]http://i721.photobucket.com/albums/ww21 ... dFiat2.jpg[/IMG]
http://i721.photobucket.com/albums/ww21 ... 24/032.jpg
http://i721.photobucket.com/albums/ww21 ... 24/033.jpg
http://i721.photobucket.com/albums/ww21 ... NGINE3.jpg
IMG]http://i721.photobucket.com/albums/ww21 ... NGINE4.jpg[/IMG]
Will post pics of the coupe's engine bay with its new cold air box for the 44 IDFs soon, as the box is about a week away from being completed. This new box is made from composite materials to absorb sound, be light weight, take advantage of all the limited space available under the hood, provide 100% cold air to the carbs, and flow well enough to feed those 44mm bores on the IDFs. Will also be doing some dyno runs with the new air box in the next few weeks.
sptcoupe, looking forward to seeing what you get with that cold air intake. Do you have before dyno # you can compare with?
