Hey gang.I have a small issue with my 82
I am getting a popping sound from the pass. rear of the car.Hard to describe,but kinda like when you run over a rock with the edge of a tire.I seem to get it when the suspension loads and unloads on hard cornering,or even when the car is loaded/unloaded on uneven ground.I have tightened everything underneath,that I can.This includes panhard,trailing arms,shocks.I have checked the spring buckets also.Everything was tight. All the rubber bushings appear to be fine.My exhaust is a bit of a mess,but I dont think the pipe hitting is the noise I am hearing.It doesnt do it all the time,fairly intermittent.I do not believe it is driveshaft related either.Any thoughts?? I have pulled ,prodded,yanked,and compressed everything,but I cant make it do it on jackstands or on the ground.
Any feedback is,as always,appreciated
