custom round tail lights done ...
v6spider
Post by v6spider »
Just needs fine tuning...
http://www.v6spider.com
azygoustoyou
Re: custom round tail lights done ...
Post by azygoustoyou »
Looking good. What lights did you use?
v6spider
Post by v6spider »
Hi Brady,
They are custom made from 2 1/2" Truck Marker lights and and white PVC plumbing fittings... the inner lens is going to have a hole drilled in it for back-up light lens that will be powered by a super bright white LED...
I can post a pic of them if you'd like.. :)
Rob
v6spider
Post by v6spider »
grittracing
Post by grittracing »
are they LED? Looks good !
v6spider
Post by v6spider »
a hybrid actually the Tail-Stop-Turn part is an incandescent...The BU Lights are LED...What you are seeing in the lit up photo is the reflection of the flash in the lens.. :)
Rob
mdrburchette
Post by mdrburchette »
I think it'll look good once you've completed your project. Has anyone thought to slant the two lights to match the shape of the rear fender?
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
v6spider
Post by v6spider »
I think you'd have to have a light that was able to shoot straight on built with the angle in it... does that make sense? When intially designing for round taillights i tried out what it would look like to flush mount them and i didn't like to the results... frenching looks better in my opinion.. :)
UPDATE: Denise, I thought about your query again... did mean following the slight angle that occurs from the edge of the trunk lid to the outside of the top f the fender. If so I thought about that to but never tried it. The first v6spider had round 2 1/2" taillights too except there were three a separate one for bu lights I eliminated that for version 2.0.... the bu lights are in the center of the inner taillights...
Cheers!
Rob
mdrburchette
Yes, that's exactly what I meant. Two round lights positioned at a slight angle to follow the flow of the back of the rear fender. I think it would compliment the natural lines of the car. Of course, what's in my mind may not necessarily look all that great in real life. :?
v6spider
Post by v6spider »
Yay I guessed it... when i visualized it... it just didn't seam as appealing... sorry ... the orignal idea was from the dino spider... ferrari and the like.... all of those examples were in a line ...
Rob
