Driving lights in grill?
deacon
Post by deacon »
I am really interested in mounting driving lights in front of the grill on the 78 Spider. I have taken a close look at it and taken measurements. I really don't want to have to go to every web site or parts store in the world to find something that works if I can borrow from someone's experience. I am looking for a suggestion(s) on specific lights that have worked for any of you. I don't want to use any of the current look little lights. I am looking for something that looks a bit more "classic".
There is no bumper on the front of tha car.........
Re: Driving lights in grill?
we've put 4" KC lights in the corner of the upper grille and 7" Hella lights in the lower grille
deacon
Post by deacon »
Thanks Mark
Daniel
Post by Daniel »
If you do some searching around you'll find some photos of cars that have this done already
many people like this look i can't remeber who or where i've seen them but they are in here
some place . :D
SouthSwedeSpider
Post by SouthSwedeSpider »
I got a pair of old Bosch fog lights on eBay. I believe they are as old as the late 50ies actually, but I thought they suited the car.
They are 6" wide outer diameter and about 2,5" deep. I drilled two small holes per light through the lower part of the grille frame, and mounted them with two M4 bolts. The hood can still be opened, although I have to be a bit careful not to open it too forcefully. They came with 45 W bulbs for Bosch Ba20s sockets, but I managed to find 50 W halogen bulbs at http://www.vintagemotorspares.com/phdi/ ... ent&part=7. I think 6" Bosch Knicks, like these http://www.tradera.com/Extraljus-Bosch- ... _127619917, would work fine as well.
baltobernie
Post by baltobernie »
Some put the lights behind the grille.
http://www.dcfiats.org/members/images/E ... -large.jpg
azruss
Post by azruss »
I am planning on mounting 4 1/2" harley lights. price is reasonable and the lens is glass, not plastic.
deacon
Post by deacon »
Excellent feedback, thanks.
spiderrey
Post by spiderrey »
I did this years ag with a set of yellow lights. Hanging behind the grill from the support in front of the rad.
Swede, your headlight rings dont look stock. They look alot deeper?
azygoustoyou
Post by azygoustoyou »
azruss wrote:I am planning on mounting 4 1/2" harley lights. price is reasonable and the lens is glass, not plastic.
You'll have to show us what they look like when your done. :P
SouthSwedeSpider
Spiderrey, I think the rings are stock, it might just be the picture that makes the lamps sit deeper. The headlights have been changed at least twice, first when the car went from Germany to the UK, and then when I brought it over to Sweden.
wikkid
Post by wikkid »
I suppose on a newer Spider, you could use the bumper posts as mounts for fog lights. Hmmmm.
salspaugh1
Post by salspaugh1 »
Good morning! I have a question. Where did you pull your power from for the driving lights? Did you go directly off the battery or find another source. I thought about going off the fuse box, but not sure which connector. I would appreciate any feedback you can provide. I'm sure there is a good source somewhere. Sounds rather elementary, but figured this forum is the best place to ask the question. Thanks for your help.
Steve Alspaugh
1981 Spider 2000
donm
Your car is a: 1980 spider [carb]
Post by donm »
What I did was tap right off the output stud on the alternator.
1979 Spider
2001Saab SW
2004 Saab Aero
SouthSwedeSpider
I have two separate 5 pole relays, one for the low beams and one for the high beams/driving lights. I joined the cable from the left driving light and the left high beam together, and attached it to one of the two outgoing poles in the high beam relay (terminal # 87 on the relay). Then did the same on the right side and connected them to the other terminal # 87 on the same relay. The relay is fed through the alternator via terminal # 30 on the relay, with an in-line fuse. The other relay takes care of the low beams, one lamp per terminal # 87, Daniel Stern has some really useful info around this: http://www.danielsternlighting.com/tech ... elays.html
