New Fuel Rail
unplugged
Your car is a: 1981 Spider
New Fuel Rail
Post by unplugged »
The engine will eventually be MegaSquirted. It has a worked head and cams courtesy of GC and HC pistons so I needed larger injectors. I decided to redo the fuel rail as well to more easily accommodate non-stock injectors.
The individual feed lines for each injector are a bit longer than I like but the geometry makes a shorter run difficult unless I can find a way to mount the rail lower.
'81 Spider
is the fuel rail going to clear the brake master?
mbouse
Post by mbouse »
looks good on the stand. when are you stopping by for a test spin?
spiderrey
Post by spiderrey »
whats up with the turned oil filter mount? i like your set up, its not to different then mine. havent got the injection yet though
unplugged
Post by unplugged »
The oil filter hangs down. It doubles as the alternator mounting bracket. As memory serves me it is mounted properly. It has been several years since I took it apart so we shall see.
Good question re: the master cylinder. If it does't I will have to rethink how the rail is mounted. If I cam move it lower I could shorten the indiv. injector feeds and make it much smaller.
'81 Spider
spiderrey
Post by spiderrey »
ok, now i remember that from my ol 79. the alt is on the other side of my 2 liter in the 70.[img][img]http://i4.photobucket.com/albums/y137/s ... der033.jpg[/img]
not a very good pic from below, but you can see the alt in front of the exhaust. would like to have very detailed info on your injection mods, as im headed in that direction
