So I installed a 32/36 Weber carb and single plane manifold on a '79 Spider. My issue currently is that no fuel is getting up to the carburetor from the fuel pump. Before the conversion everything was fine and the fuel pump was working and the car started up easily. now the pump is putting enough fuel in the carb to keep it running. I can pour fuel directly into the carb to get it to run but after the bowl is empty it dies.
Is my fuel pump dead?
Am I missing something?
Any advice would be helpful.
32/26 DFEV Weber conversion problems
Dave-O Supreme-O
1979 Fiat Spider 2000 "Fiona"
Re: 32/26 DFEV Weber conversion problems
Some suggestions...
Will it pump into an empty container?
Make sure you have the correct line running to the pump if you removed it at some point.
Remove carb top cover and verify float settings, float pivots freely, and needle/seat move okay.
Buy a cheap electric just to rule out your pump didn't decide to give up.
its the auxiliary shaft, broken from misaligned timing. live and learn and pay money I guess...
Dave-O Supreme-O
I bet someone here has one, try John, "spiderparts".
- MattVAS
- Your car is a: 1976 Fiat Spider 124
The Auxiliary shafts are available new but they aren't cheap by any stretch (although not otherworldly expensive).
Finding good used ones really isn't all that hard. Matthews' Foreign Car might have some.
Matt Phillips
Vick Auto - Manager
http://www.vickauto.com
Stock parts or Performance parts we've got what you need.
Vick Auto - Manager
- chrisg
- Your car is a: 1971 FIAT
oh, dang! that sucks. did you change the belt the same time as the carb change or something? Or do you just have really bad luck?
Chris Granju
Knoxville, TN
Knoxville, TN
RRoller123 wrote:I bet someone here has one, try John, "spiderparts".
Thanks, but I already have one on the way
Dave-O Supreme-O
Users browsing this forum: No registered users and 21 guests
