air cleaner I and E alignemnt
wade71
Your car is a: 1976 Fiat Spider
Postby wade71 » Thu May 18, 2017 3:18 pm
Where does the "I" and "E" go on the top of the air cleaner?
Your car is a: Fiat
Re: air cleaner I and E alignemnt
Postby So Cal Mark » Thu May 18, 2017 3:55 pm
it depends if you want to draw in cool air or warm air
Mark Allison
allisonsautomotive.com Fiat and Alfa Romeo parts and service. Performance parts our specialty!
Headers, ignitions, wheels, cams, flywheels
Texafornian
Postby Texafornian » Sun May 21, 2017 7:19 pm
Trivia time - what do the letters stand for?
Daniel
xjware
Your car is a: 1978 124 Sport Spider
Postby xjware » Mon May 22, 2017 10:36 am
I = Inverno = Winter
E = Estate = Summer
1978 124 Spider
Central Indiana Italian Car Association
http://www.ciica.me/
nelsonj
Your car is a: 1972 Spider 124
Postby nelsonj » Tue May 23, 2017 12:06 am
E = Estate = Summer
So the idea is you have to decide if you want hot air (being drawn in from over the exhaust header) or cooler air (drawn in from the center of the engine compartment) to enter the carburetor. The top of the air filter housing has a "block plate" on it and the air filter has to "sources" it can get air from. In the summer, you (typically) want the "cooler" air entering the carb, so you turn the air housing so the block plate "blocks" the inlet coming from the exhaust manifold, and allows cooler air to enter from the engine compartment.
In winter, you want warmer air going into the carb, so you rotate the air filter housing so that the block plate "blocks" the cooler air passage and opens up the path to the hotter air from the exhaust manifold.
Here in so Cal I just leave it in the "I" position at all times (to get the cooler air). However, if I lived in a cold-winter climate I'd rotate it to "E" during the winter.
Hopefully this answers your question.
Peace.
Out.
Simi Valley, California
Spider 1800
Romans 10:9
Users browsing this forum: No registered users and 41 guests
