Any info on a DIY fuel vapor canister rebuild?
Cutting it open location....top or bottom?
rebuilding - refilling supplies?
79 fuel vapor canastor (in engine compartment)
- Your car is a: 1979 Fiat spider 124
79 124 spider
08 Silverado
09 HHR
08 Silverado
09 HHR
- Nanonevol
Re: 79 fuel vapor canastor (in engine compartment)
There's a spring mechanism in the top. I think the simplest thing would be to cut/drill a hole in the side. Wouldn't need to be too large to pour out the charcoal.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
Nanonevol wrote:There's a spring mechanism in the top. I think the simplest thing would be to cut/drill a hole in the side. Wouldn't need to be too large to pour out the charcoal.
That is just what I was thinking of doing. Thanks for the info on the location of the spring
79 124 spider
08 Silverado
09 HHR
08 Silverado
09 HHR
http://www.fiatspider.com/f15/viewtopic.php?f=5&t=18065 for a look inside. The hole in the side sounds promising. Let us know how you make out.
- Nanonevol
I remember seeing a picture where someone cut off the top - like opening a can. There was a spring that I suppose holds the charcoal down (?) and it seemed like it might be tricky to reassemble.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
How expensive are new ones from AR?
I cut off the top at the seam.
remove all inners.
replaced the charcoal with fish tank filter charcoal.
replace the foam fillers with sponge material.
Now glue is drying for refastening the top to the canister.
Then I will wrap the seam area with Flex Tape.
remove all inners.
79 124 spider
08 Silverado
09 HHR
08 Silverado
09 HHR
Users browsing this forum: No registered users and 15 guests
