Tramsmission shift stick feels sloppy
- Your car is a: 1982 Pininfarina Spider
Its time for a new clutch but i have also noticed that the shifter seemed more sloppy than usual. I have done the shifter cup replacement part set. What should i be looking for as worn parts to do with the shifter?
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
- spidernut
Re: Tramsmission shift stick feels sloppy
It is usually caused by this part being worn:
http://midwest-bayless.com/p-14460-shifter-lever-ball-plastic-bushing-fiat-124-spider-coupe-to-1972-oe-nos.aspx
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
- Patron 2019
- Your car is a: 1979 spyder 124
Hi
Recently spent the winter wrestling with a rattly change , finally fixed it . See my long thread in this section .
Key points: installed a short throw shifter ; gives a nicer action and eliminates one potential source of noise
Added the anti rattle spring which was not present when I stripped the gear shift
Result , no noise , short precise shifts >
Good luck
maxdog
Good luck
maxdog
Users browsing this forum: No registered users and 24 guests
