seat track ball bearings... size?
scampbel98
Your car is a: 1980 Fiat 124 carb
Contact:
Postby scampbel98 » Mon Oct 16, 2017 4:17 pm
holy crap those seat rails are a PITA.
Anyone happen to know what size those ball bearings are?
scampbel98
Contact:
Re: seat track ball bearings... size?
Postby scampbel98 » Tue Oct 17, 2017 12:19 pm
for anyone who's rebuilt the seat tracks.. how many bearings are in these things originally.. It looks like only 3-5 per side or about 5-10 total. Any one know?
kmoses
Postby kmoses » Wed Oct 18, 2017 10:29 pm
You might want to check out this post. This is much easier than working on the factory rails.
viewtopic.php?f=7&t=33447&p=259392&hilit=seat+rail+replacement#p259392
scampbel98
Contact:
Postby scampbel98 » Thu Oct 19, 2017 3:22 am
kmoses wrote:You might want to check out this post. This is much easier than working on the factory rails.
Thanks!!!
bluespider262
Postby bluespider262 » Mon Oct 23, 2017 4:58 pm
I've been running those sliders for over 1,000 miles now. No issues at all once I got everything bent up properly. Had to pull the seats a couple of times to get to that point. I found everything fit better with the lever pushing down to release. Only had to drill some small holes in the seat pan to clearance. Otherwise you'd really have to cut out the seat pan to clearance it enough to pull up for release (or use 1" spacers between track and seat which I didn't want to do) IIRC.
I noticed my aftermarket CJ5 seat sliders have a lever that moves side/side instead of up/down, and also locks on both sides which I feel is a must. IMHO the stock one-sided locking probably contributes to the seat frame twisting up when bigger people like myself sit in them.
Anyway these honestly might work better in our spiders than the ones I ended up using in that other thread and I think they are made better too. https://www.amazon.com/MasterCraft-Safety-620030-Seat-Slide/dp/B005JVF98S
Users browsing this forum: No registered users and 19 guests
