My drive shaft bolts seem to keep working themselves loose - and the car doesn't get driven much.
I'm planning to grab some Grade 8 bolts, aircraft nuts and washers... any reason that shouldn't work and stay tight?
drive shaft bolts - loose again
- Your car is a: 1980 Fiat 124 carb
- Contact:
Re: drive shaft bolts - loose again
If the shaft is not assembled with each section oriented to each other the same as when it was originally balanced then it will be vibrating and working the fasteners loose. A worn hanger bearing can also cause this as will worn out fasteners or under tightened fasteners.
- Nanonevol
How about some loctite?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
You need nut with nylon
Is this at the guibo? They alternate facing front to back, maybe oriented incorrectly?
- lglade
It's been a couple years since I did mine, and as I recall the nuts have nylon locking. Generally these are supposed to replaced after they've been removed once, so like OXFORD2004, I think you should start by replacing the nuts.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
2015 Subaru Outback
2017 Ford Focus RS
Users browsing this forum: No registered users and 19 guests
