Got a crunchy sound that I think is coming from the rear pax side. I've removed the axles and have ordered new rear bearings. No one in town had them. I'm going to get the pressed on and off at a shop. There's a couple of super thin o-ring seals or gaskets where the bearing meets the caliper carrier.
Where can I find or source those. Vicks, Mr. Fiat.. no one has them...
thanks
Rear wheel bearings
- Your car is a: 1980 Fiat 124 carb
- Contact:
- Nanonevol
Re: Rear wheel bearings
Is this it?
https://autoricambi.us/products/rear-axle-shaft-bearing
Oh, sorry, you need related parts. Maybe A/R has them?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- Contact:
sorry. to be clear, I found the bearings at Vicks but no one has the o rings
I just replaced my rear axle seals and the O-rings two weeks ago, AR had both items in stock.
Use some heavy grease to keep the O-ring in place on the bearing and keep it from rolling.
https://autoricambi.us/collections/driv ... oring-seal
https://autoricambi.us/collections/driv ... e-oil-seal
- Contact:
thanks KMoses.. I must have missed those somehow. thanks for the pointer...
Users browsing this forum: No registered users and 20 guests
