I have a question. I checked my valve lash and some are off, so I wanted to see if someone knew if it was still in range for driving till I get a valve lash adjuster tool to remove and check which shims I need. The lash goes as the following.
1cyl In. .012 - Ex. .017,
2cyl In. .014 - Ex. .018,
3cyl In. .013 - Ex. .020,
4cyl In. .018 - Ex. .017,
Also check compression and dry im at around 120 psi and wet(placed a little oil in the cyl) 130 psi.
Would any of you know what jets I would need for a 32/36 Weber DFEV carburator? I turned in the mix and idle screw all the way and still am running rich and idle rpm is at 1200-1400rpm.
Just installed a new Fuel Regulator and inline Fuel Gauge today between the fuel in and carburetor.
Sorry Mr. Beek I copied our text.
Thanks.
Just needing asurement on valve lash and other maintenance/updates
- Your car is a: 2003 accord honda
1978 Spider 1800
- kilrwail
Re: Just needing asurement on valve lash and other maintenance/updates
How do you know you're running rich? Are you sure the point gap and timing are properly adjusted? You should get the ignition right before doing any carburetor work.
When you measured the compression, was the engine hot ? It should be. And be sure to open the throttle all the way while doing it.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
- seabeelt
- Patron 2019
Intake should be 15 to 17 and exhaust 17-19 If I remember correctly
- Your car is a: 1979 Spider
I've been tuning all summer with a wideband so I've been up and down this lately.
its probably a bit rich. But...it should run what seems to be "perfect" despite that. It won't be rich enough to not end up in the recommended tuning range for idle/mix, but it will still likely be a point or two richer than optimal. So in reality it will seem fine but might actually need to be jetted down a bit.
Idle screw should be nowhere near all the way in. In fact quite the opposite...on a DFEV it should barely engage the throttle lever at all, literally just touching plus maybe half turn of contact. I would reset that back to half turn, let the mix out 3-4 turns, and go from there. Make sure the choke is working properly too. If you can't get solid running with those settings something else is wrong.
There's pretty good instructions on the redline carb site but I find their recommended idle screw range is a bit too wide and on the high end uncovers the transition holes too much. You are best to shoot for under 1/2 turn, at least from my experience on my carb.
Users browsing this forum: No registered users and 47 guests
