Gauges
Re: Gauges
In theory, but getting the glass out is almost impossible without destroying the bezel that holds the glass in. I'd look for an speedo service shop in your area and ask them.
Kirk
Kirk
Re: Gauges
Sure. But usually only once ... maybe twice. Use a 3/16" or 3/32" flat-blade screwdriver to gently pry the aluminum bezel outwards (from the back side). Once the gauge is removed, the lens is easily removed. Get it squeaky clean, because the thin bezel probably won't survive another attempt.njspider wrote:Can the lens be removed and cleaned??
Users browsing this forum: No registered users and 12 guests
