I've installed the Stainless Steel Braided Brake Hose Kit from AR and they look great. BUT on the front lines they kink real bad no matter how I lined them up. The metal on the banjo end is about a 1/2 inch longer and when the wheel is turned all the way it binds/kinks bad enuf that the plastic wrap is cracked after only 1 turn. This can't be normal can it? Is there a solution to this problem? Please help.
shmoky
- Your car is a: 1980 Spider 2000 Pininfarina
Chetwynd, B.C. Canada
1980 Pininfarina Spider 2000
Sold: 1968 Corvette Coupe BB to buy the Spider
Re: Stainless Steel Braided Brake Hose
Problem solved.
- joelittel
How did you fix it?
Talked to A/R. They said when the suspension is 'hanging' which is when I checked and it kinked was the problem. He says put wheels back on ground and there won't be a problem. He was correct.
shmoky
shmoky
Users browsing this forum: No registered users and 11 guests
