Greetings,
I'm in the middle of repairing my shifter. I managed to get the handle back in and have replaced the spring and the cups. I am having a bear of a time trying to get the triangle cover back on in the limited space available, mainly due to my fat hands and short fingers. Can I remove the 3 bolts that attach the guibo to the driveshaft and just move it out of the way? The guibo is maybe a year old and has very few miles on it, so I don't want to replace it at this point.
Any suggestions?
Brian
79 Spider 2000
dropping only the front of the driveshaft?
Re: dropping only the front of the driveshaft?
can be done.
good luck putting it back on
All done! It was so much easier putting the cover plate back on the shifter after dropping the shaft!
I put a big hose clamp around the guibo to make sure it didn't expand. After that, easy peasey.
Now if only the control arms would come back in stock at AR...
B
B
Users browsing this forum: No registered users and 11 guests
