Time to start putting her back together Trying to figure the least complex method for replacement of the engine & transmission. This is the first time I will have reinstalled an engine. I have previously done a clutch, many years ago, by dropping the box.
Opt 1 - Attach engine & box then insert into car.
Opt 2 - Install transmission. Install engine.
Opt 3 - Put engine in the hole but keep on hoist. Install transmission & bolt it all together.
Each seems to have pros & cons. I have cherry picker hoist but no pit so will need to spend time on my back & underneath.
Would love to hear opinions. Thanks, Steve
Refitting engine
- Your car is a: 1972 124 Sport Spider
Re: Refitting engine
HI Steve
In my opinion bolt it all together first, then install. If possible, best to install from the bottom up rather than top to bottom.
Stevelivingfree wrote:Time to start putting her back together
Opt 1 is possible but not easy to find the good angle in order to put evrything in from the top without damaging anything ...
Opt 2 definitively not ...
Opt 3 is the best Install the engine first from the top and then install the thansmission from the bottom ...
Fiat 124 Spider 1.8L 1978
Jaguar XKR 4.2L 2009
Harley Davidson Fat Bob 96Ci 2011
- aj81spider
I did option 1 (transmission bolted to engine) when I did my car. It has the advangtage of not having to deal with transmission and starter bolts, which if you search the forum are a PITA.
If I had it to do again I might remove the center link on the steering as it took a little wiggling to get by that, but even with that it was a pretty easy job. I had two people - that helps a lot. Also make sure you have a leveler on the hoist as you will want to change the angle as it slides into place.
A.J.
2006 Corvette
2006 Corvette
Steve,
I'd spend some time searching the forum here. Only about a thousand threads on the topic. I put the engine and transmission together first, dropped the center tie rod on the steering and muscled it in from the top. The only thing I would do differently next time would be to also drop the center cross member the engine sits on as well and put it back in after the engine is down in the chassis.
For sure get one other person to help. Also buy, rent or borrow the engine hoist leveler, it's a huge help. I would also have either the front wheels up on ramps or the whole car up on jack stands to be able to make all the angles on the engine/transmission work going in. You can also take the shift extension off the transmission to make the angles better as well and then bolt it back on after the transmission is more or less where it belongs. You need to take the sheet metal transmission tunnel cover off the car to do this, but I assume you already have this off.
Kirk
Kirk
Thanks guys.
Have a leveler on the hook. Like the idea of the cross member. Will take a good look at it. Will try a few more searches.
Steve
Steve
Leave the crossmember alone. It connects to the bottom A-arms. Not worth the hassle to get the suspension right again just to buy you some more room dropping the motor in.
Users browsing this forum: No registered users and 18 guests
