Vacuum LIne
- Your car is a: 1985 Spider
Vacuum LIne
I have a FI spider and it looks like I have an unattached vacuum line. The starts at the vacuum advance module and travels along the firewall. I'm not sure where the other ends should be attached. Any ideas?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
- So Cal Mark
- Your car is a: Fiat
Re: Vacuum LIne
there is a vacuum nipple below the throttle plate on the intake plenum
Mark Allison
- Your car is a: 1980 Fiat Spider 124
Re: Vacuum LIne
Sorry to hijack this thread, but I have the same issue. Does anyone happen to have a good pic of that nipple? I've looked for an hour and can't find it. ..thanks
1980 124 FI 2000
- Your car is a: 1981 fiat 2000
Re: Vacuum LIne
That is not the nipple for vacuum advance . (Previous picture) . That , instead is vacuum hose that goes to top of charcoal canister
Re: Vacuum LIne
I don't have photo, but feel under the big black hose (cyclonic oil/vapor separator hose)that attaches to throttle plate just near where end of throttle cable is attached to engine
Re: Vacuum LIne
Yep, it is just about under the big coiled throttle return spring, on the throttle body. Small diameter, points horizontally straight out towards the rear.
Re: Vacuum LIne
awesome, I found it...but I had some other hose hooked up there...so I've switched them, but now need to find where this new hose goes. The other end is attached to a small white rectangular box that's mounted on the driver side wall of the engine bay.
here are two different pics of the little white box...can anyone tell me what this thing is below the yellow circled item? (ignore the yellow circle, that was for another post.. )
and here in the top right corner of the pic
thanks again
Ed
thanks again
Ed
1980 124 FI 2000
Re: Vacuum LIne
Okay so it turns out the little white box pumps water for the windshield wiper spray. ..problem solved
Ed
Ed
1980 124 FI 2000
Users browsing this forum: No registered users and 20 guests
