fuel injector spins
fuel injector spins
replacing brake servo and master so just fumphering around in the general area and found front cylinder injector loose and spinning even with the single stud hold down bottomed out. Is this OK What are my options to make right
Re: fuel injector spins
Yes it is
If there was any work done on the injectors in the past, the plate holding the injector in place may be upside down.
- aevansgatech
I have nearly the same question
I took our the fuel rail and injectors to replace the short hoses and now that it's reinstalled, there is some play in the injector mounting plates. I didn't notice upon removal if they had that same amount of play, but I also don't want to overtighten the single nuts or strip the studs.
Is it normal to have some play in the injector mounting plates or should I reinstall?
1979 Spider 2000 (gone)
No free play on mine. That suggests something not quite right.
Perhaps old rubber seals on injectors?
- aevansgatech
Any recommendations on the order of assembly?
I took the whole fuel rail/lines/injectors out of the vehicle to work on them. Anybody know if it's easier to seat the injectors first, then add the fuel rail or just try to get the whole thing in all at once? I had a hell of a time trying to fit the whole assembly in there.
- lglade
aevansgatech wrote:Any recommendations on the order of assembly?
I did mine as an assembly (fuel rail + injectors) and reinstalled it with new seals with a light bit of lithium grease on them. Mine went together pretty smoothly, but each injector took a little wiggling to seat it.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
2015 Subaru Outback
2017 Ford Focus RS
- aevansgatech
Thanks lglade,
It must be the seals preventing me from getting the assembly in all the way. I'll try again with a bit of grease and make sure the injectors are fully inserted.
I installed my rail and injectors fully assembled, and a quick trial placement showed which way to orient the clamps so I could get at them after installation. Making the 4 hose sections a TINY bit longer than needed puts a SMALL inconsequential arc in them, and keeps an inward seating force on the injectors, after the rail is socked down.
- aevansgatech
Quick update since I got it all back together. I was having no luck installing it together, so I opted to install the injector/hose combos individually. That gave me the space I needed especially for cylinders 3 and 4. I then found it easier to maneuver the fuel rail onto the four injector hoses without much hassle.
I let her run for the first time all winter yesterday and cycled the fan on and off a few times. I'm ecstatic there wasn't a single drop of fuel or hint of leaks.
Excellent!
Users browsing this forum: No registered users and 9 guests
