I want to fix rear seat belts on my spider azzura (1984) 2 liter and I wondering if there are the holes (for the center belt) in the car or I must do them myself ?
Anybody did the same improvement ?
rear seat belts in a spider
- Your car is a: Fiat spider 1984 from california
- Yadkin
- Your car is a: 1974 Spider
Re: rear seat belts in a spider
My '74 has threaded holes on the sides only. If you purchase retrofit belts, you can buy an optional kit that will have new bolts, nuts, and large washers that reinforce the area that you would drill holes.
Lap belts would be an easy retrofit. Three point belts with a shoulder belt would be far more difficult because of the height of the seat relative to the bottom of the convertible top.
- Your car is a: 1982 spider
if you search the forum there's an excellent write up on the step by step procedure. Has pictures of exactly where to locate bolts and washers and a link where to buy the kit. I followed it and worked perfectly. Took less than an hour
- njoconnor
- Your car is a: 1972 124 Spider
Our 72 had regular, threaded mounts in the "back seat" area. I installed extra long belts, not for passengers, but for hauling the "3 G's": golf clubs, guitars, and Golden Retriever (in her doggie harness/vest). No humans are subjected to that area.....
Neil
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
Madison, WI
72 FIAT 124 Spider
- Ptoneill
gbraun wrote:I want to fix rear seat belts on my spider azzura (1984) 2 liter and I wondering if there are the holes (for the center belt) in the car or I must do them myself ?
I thought that the rear "seat" was removed from the Azzura"s?
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
Users browsing this forum: No registered users and 12 guests
