Birds Eye Maple Wood Kits
Your car is a: Fiat
Postby So Cal Mark » Wed Sep 28, 2016 1:09 am
We had our wood mfg make up sets of birds' eye maple. The kits contain the cluster, glove box, shifter plate and 2 small center strips. We have them for 78 and earlier with 6 gauge holes, 79 and later with 5 holes and custom cluster for 79 and later with 6 holes so you can add an oil pressure gauge without eliminating the clock. These are all in stock now at $350 per set plus shipping. Matching shift knobs coming soon!
Mark Allison
Exit98
Your car is a: 76 Yellow 124 Spider
Re: Birds Eye Maple Wood Kits
Postby Exit98 » Wed Sep 28, 2016 12:13 pm
Hi Mark,
They look very nice. On the glove box door, are there inset nuts on the back for the two hinges?
Thanks.
Doug
76 Yellow Spider at the Jersey Shore
davery
Your car is a: 1985 Spider
Postby davery » Wed Sep 28, 2016 12:20 pm
So Cal Mark wrote:We had our wood mfg make up sets of birds' eye maple. The kits contain the cluster, glove box, shifter plate and 2 small center strips. We have them for 78 and earlier with 6 gauge holes, 79 and later with 5 holes and custom cluster for 79 and later with 6 holes so you can add an oil pressure gauge without eliminating the clock. These are all in stock now at $350 per set plus shipping. Matching shift knobs coming soon!
No love for the 83-85 owners?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
Your car is a: Fiat
Postby So Cal Mark » Wed Sep 28, 2016 12:33 pm
the problem with 83-85 is the center stack is not wood, it's a plastic applied to a metal backing. We've done several 83-85 restorations and we use vinyl wood to redo them.
The glove box door does have threaded inserts for the hinges
Mark Allison
KWL82
Your car is a: 1982 spider
Postby KWL82 » Wed Sep 28, 2016 12:48 pm
Mark thanks for all the custom work. I know it would be time consuming to do but would really help to sell if we could see specialty stuff actually on a car to gauge final appearance. Again i know its quite a bit of work but i think help to see in 'action'
Your car is a: Fiat
Postby So Cal Mark » Wed Sep 28, 2016 2:47 pm
the videos of our restorations are all posted and all of the 84 dashes we've done have been in vinyl.
Here's one example; all of the videos are on my youtube channel.
https://www.youtube.com/watch?v=nIY5BDNUVkw
Mark Allison
davery
Postby davery » Fri Sep 30, 2016 8:24 pm
So Cal Mark wrote:the problem with 83-85 is the center stack is not wood, it's a plastic applied to a metal backing. We've done several 83-85 restorations and we use vinyl wood to redo them.
I hear you. I veneered the center stack and am not really happy with the results. The metal is thin and it bends very easily, which cracks the veneer. I'm thinking of making new metal prices for the center console out of heavier gauge metal and veneering again. But then I'm going to have to worry about the vents and switch bezel attaching correctly to the upper center section.
Don Avery
1985 Pininfarina
2011 Eos
Return to “Custom Stuff”
