Timing Cover - Better Options
spiderrey
Re: Timing Cover - Better Options
Postby spiderrey » Fri Dec 26, 2014 11:53 am
Looks good. I would clean up those fan blades though.
azruss
Postby azruss » Fri Dec 26, 2014 3:19 pm
My first spider had a casted cover and i never liked the look of this big yellow plastic piece. The plastic also gets dirty and hard to keep looking pristine. I painted mine silver with a urethane clear coat. The clear coat made the silver base react and it came out with a hammered look. The best part is the urethane finish is so easy to keep clean
nelsonj
Your car is a: 1972 Spider 124
Postby nelsonj » Sat Dec 27, 2014 12:45 am
I cut my cover also - you did a much better job than me!
Peace.
Simi Valley, California
Spider 1800
Romans 10:9
twincamspit
Your car is a: 1976 Fiat 132 based
Postby twincamspit » Wed Jan 14, 2015 5:19 pm
A quick update on the Fiat Twincam split alloy covers that Revival Motorsport Fabrications are making - I received some photos of their prototype today and it looks great, can't wait to get my hands on it soon for test fitting :-)
https://www.facebook.com/media/set/?set ... 42fb6fe7bb
donerehart
Your car is a: 1976 spider
Postby donerehart » Wed Jan 14, 2015 6:54 pm
I would certainly purchase one of these! Thanks for pursuing this!
Don
76 Spider
St. Louis, MO
Your car is a: 76 124 Spider
Postby 76124 » Wed Feb 11, 2015 11:15 pm
Any update on the price point fOr these?
Kraig
Everett, WA
76 Spider owned just shy 30 yrs and counting
69 Spider - Big truck ate it :cry:
74 Sedan special TC Auto..Died of cancer RIP
georgeramos
Your car is a: 1971 124 Spider 1608
Postby georgeramos » Sat Feb 28, 2015 8:15 pm
Yeah, Im interested if it can work with a 1600.
BellaMachina604
Your car is a: 1982 Fiat 2000 Spider
Postby BellaMachina604 » Sun Oct 18, 2015 10:23 pm
You definitely have to do the coolant when you replace the timing belt because, timing cover or no timing cover, you have to remove the top two coolant hoses to remove/replace the belt. Still, a pain to remove the water outlet (snorkel) though. I cut through my timing cover so it slides up under the outlet.
QuebecFiatSpider
Your car is a: 1980 Fiat Spider 2000 FI
Postby QuebecFiatSpider » Tue Sep 05, 2017 7:26 am
I'll be following that thread for sure :)
twincamspit
Postby twincamspit » Mon Feb 26, 2018 4:25 am
Hi guys, apologies for the late response. Few family matters meant I've not been doing much car related for quite a while.
It seems Ricambi got the exclusive rights to sell the split aluminium covers in the USA:
https://autoricambi.us/collections/new- ... er-1979-85
Got to say, I'm very happy with mine. A bit fiddly to refit the top half due to lack of space between radiator and engine, but a heck of a lot easier than draining down the coolant each time to access the pulleys.
Kinda tempted to leave the top half off, to show off the adjustable cam pulleys, it feels strong enough to do so.
Nolan
Your car is a: Barely Working 1972 Fiat Spider
Postby Nolan » Mon Mar 05, 2018 7:53 pm
I hope I didn't miss this in the comments but what type of paint is safe to use to redo those yellow timing belt covers?
xjware
Your car is a: 1978 124 Sport Spider
Postby xjware » Sat Mar 10, 2018 11:48 am
I have heard the Krylon Sunshine Yellow is a near match.
1978 124 Spider
Central Indiana Italian Car Association
http://www.ciica.me/
Begottenmilk
Your car is a: 1979 Fiat 124 Spider 2000
Postby Begottenmilk » Sun Mar 25, 2018 5:52 pm
Has anyone done the coverless option? Like any issues or debris that you cant get off the belt? Plastic cover thingy is kinda cracked and my JDM friends showed me how cool it can look.
Odoyle
Your car is a: 1983 Pinafarina Spider
Postby Odoyle » Mon Mar 26, 2018 2:47 pm
Not the best idea to go cover-less, dirt, stones and road debree can become lodged between on on the teeth of driven pulleys causing host of issues. IF you had the original lower engine belly pan than you might be able to get away with not having a cover.
Return to “Custom Stuff”
Users browsing this forum: No registered users and 15 guests
