Crinkle painted timing belt cover
Thought this came out pretty good. Had it painted silver. Always a pain to keep it clean.
Re: Crinkle painted timing belt cover
How did you do it? Prep, etc.?
Sanded with 200. Just too rough up the existing paint. Cleaned with acetone. You spray 3 heavy coats of crinkle waiting 10 minutes between coats. In about 6/8 hours it crinkles. Cool stuff. The stuff I used is Plastcoat Wrinkle paint.
Here's the part #. PlastiKote 217 Black Wrinkle Paint - 12 Oz.
$10.00 on Amazon. You should me able to find it locally at Autozone or Pepboys.
I did the dash of a 68 MGB with this paint. Came out looking like original. I think it would also look good on the rear view mirror of the 124.
- Your car is a: 1982 Spider 2000 - CSO
Looking good!
Are you going to do anything with the valve covers?
SunnySideUp
After polishing, what do you coat them with to keep them from re-oxidizing?
I just use Semichrome paste. With the low humidity here the oxidation isn't that bad.
Thanks for the info, Tuc. That crinkle looks pretty nice.
Did you paint your exhaust manifold?
Yes, I use Thermo-Tec High Heat Coating. Good to 2000 F.
- spidernut
I tried doing the same with my cam covers and found it too slow of a process. What are you using to sand/grind down the surface to that nice of a smooth finish and shine?
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
- v6spider
Cam covers are aluminum...I'd strip any paint and hit them with a buffing wheel...I've seen it done...looks awesome polished up.
Rob
Rob
http://www.v6spider.com
http://www.fiatspider.com/f08/viewtopic.php?f=15&t=4279
http://www.fiatspider.com/f08/viewtopic.php?f=15&t=18063
- Your car is a: 1980 spider [carb]
Hey Tuk,
I notice you don't have the heat shield over the exhaust manifold. I'm wondering if that might cause problems with the paint on your hood, especially when the weather gets warm.
1979 Spider
2001Saab SW
2004 Saab Aero
2001Saab SW
2004 Saab Aero
Users browsing this forum: No registered users and 19 guests
