Alternative dash gauges
- Your car is a: 1978 Fiat Spider
Anyone have experience with alternative gauges in the dash?
Like Autometer or anything digital? I was thinking about swapping Oil / Gas / Tach and Speedo with something a little more updated. Don’t even know where to start with the sender units.
78 Fiat 124
Re: Alternative dash gauges
78 Fiat 124
intellitronix.com the problem is to built the adaptor for the electronic speedometer
- chrisg
- Your car is a: 1971 FIAT
I have a good bit of experience. This is a 124 Spider that has an autometer tach and a mechanical VDO oil pressure gauge. This car is a purpose built, so there is no need or desire for matching aesthetics. In fact, you may be able to barely make out the corrected speeds stuck on the face of the speedometer to correct the vastly incorrect readings. I drive using the tach, not the speedometer anyway.
Also, in the area of alternative 2" (52mm) gauges, I recently picked up a handful of these & made this panel for an X1/9 (obviously, these could also be used in a 124). These are electronic, via ebay.
This is a test fit with some clean-up & a toggle switch replacing the hazard switch forthcoming. I am adding a resistor to the lighting (bright, LED) so they will better match the typical Fiat gauge at night.
I have also usually replaced clocks with voltmeters. You used to be able to find voltmeters from Jaguar dashes that would match the aesthetics of the Veglias, but you would have to change the green back-lighting to clear.
I suppose the speedometer is the gauge that would give someone more grief, but I've never felt the need to do much there (other than I may end up with 124 gauges in an X 1/9 or I've dabbled with 124 gauges in a 128...but all Fiat/mechanical).
Chris Granju
Knoxville, TN
Knoxville, TN
Actually Glow shift offers a gps unit for Speedo.
That’s what started this whole idea. My Speedo has never worked.
Hmm!!!! What about gauge sizes? anyone have those in handy?
78 Fiat 124
chrisg wrote:I have a good bit of experience. This is a 124 Spider that has an autometer tach and a mechanical VDO oil pressure gauge. This car is a purpose built, so there is no need or desire for matching aesthetics. In fact, you may be able to barely make out the corrected speeds stuck on the face of the speedometer to correct the vastly incorrect readings. I drive using the tach, not the speedometer anyway.
Something about this setup makes me happy. All purpose build = fun in the sun!
78 Fiat 124
Will someone Please confirm...
Small gauges are 2” (52 mm) ??
What about Speedo / Tach 3.75” (95 mm) ??
78 Fiat 124
- chrisg
that sounds right...I always thought of them as 4". On the 124 I posted a photo of, the tach is larger, but I don't recall if the base is actually larger than the stock ones. That panel is a cut piece and in reality a 124/Spi2K may be one of the simplest cars still on the road to make a custom dash panel for.
and, yes, that car is absolute fun...to me the ideal 124 Spider
Chris Granju
Knoxville, TN
Knoxville, TN
Well I took the plunge. Ordered 7 gauges. Will post pics of results soon.
78 Fiat 124
Update: Gauges installed. It was a little nerve racking bc my previous panels were laser cut.. and I no longer have access to that equipment!
So the tach / Speedo are slightly smaller then the original.. but, I was able to take the black ring off the original and use it as a “washer” between the wood and new gauge. Works like a charm!
Other things to note, had to trim each of the retaining clips on the back of the smaller gauges. No big deal, 15 second task with drimmel tool.
Still looking for “hoods” for the Speedo and tach. After taking it out in direct sun, this is a must.
I’m happy the way it turned out. Just ordered a signal indicator to replace the trip reset knob. The pics looks like black stain, but it really opens up in sun.
78 Fiat 124
Speedo - hooks up to GPS
Tach - straight to coil wire
Volt - any + wire
Oil - has a sending unit (1/8 npt)
Fuel pressure - unit between carb supply line
Water temp - sender unit on hose (1/8 npt)
Gas level?
Volt - any + wire
Gas level?
78 Fiat 124
If it helps. I have a brand new tank / sending unit from AR.
78 Fiat 124
Gas level - this one I’m stumped about. The unit I have is adjustiable. (See options. Slow in table).
Does anyone know how the original gas level works?
Solid white wire - backlight
Pink - ?? Is this my sender ground wire (ohm)
Yellow / black - ?? Low fuel something?
Black / white stripe - ?? I think this is ground?
Red - low gas indicator light (positive?)
78 Fiat 124
[quoteDoes anyone know how the original gas level works? ][/quote]
2 choices. Fill the tank and check reading or remove sender and check reading moving the arm to full and empty.
Users browsing this forum: No registered users and 23 guests
