Clock stops
Clock stops
OK. Why would the clock stop when the lights are turned on? Found it out tonight and laughed out loud. What next?
- nelsonj
Re: Clock stops
Voltage drops to the clock. Check all the ground pods, and check to make sure your voltage from the alternator is about 14v when the engine is running. It possible the regulator is going bad.
Simi Valley, California
Spider 1800
Romans 10:9
Re: Clock stops
Solved. broken wire at connector.
Re: Clock stops
You didn't have to fix it for it to be correct twice a day!
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
Re: Clock stops
zachmac wrote:You didn't have to fix it for it to be correct twice a day!
If he can drive through time zones it could be right like 6 times a day...how often do you need to check the time anyway?
