Hi Everyone. I am trying to install the bumperless turn signal lights, but I am not sure I am doing it right. I have shaved off quite a bit of the bumper hole and they still do not fit. Can you look at the pictures and let me know if I am doing this right?
Thanks!
Bumperless Lights Install
- Your car is a: 1984 Fiat Spider
Re: Bumperless Lights Install
Hi. Just checking to see if anyone has pictures of the size hole they needed to create to insert the lights. I was hoping I would only need to enlarge the hole a little bit so if I wanted to put the original bumpers on I could. Does anyone have any details on size of the hole and/or positioning of the light going into it?
Thanks much!
Rob
Thanks much!
Rob
- So Cal Mark
- Your car is a: Fiat
only remove material from the top and bottom of the hole
Mark Allison
Thanks. That is what I did - although my picture is not too clear. How much is typically required to remove? Is my position of the light ok?
- 81SPIDERMATT
take out till it fits .... mine ended up just like you have in your pic ... the fatter side of the housing to the outside and the screws that hold the lens are "almost horizontal" .... I remember just liking the way that it fit against the car ... I also remember that to me it sorta looked cross eyed when looking at both lights ... like maybe they should have spun 180 degrees ... but really did not like the way they laid against the car that way ... but at the same time I had just removed the front bumpers so I was sorta love struck with that look and did not care that the lights seemed a bit off ... now I cant imagine them any other way ... Matt
edit .... after looking at your pic mine are 90 degrees different than yours
- 81SPIDERMATT
ok that last pic looks just like mine ... maybe I am wrong but that first set of pics looks different than the last ... no? .... Matt
Users browsing this forum: No registered users and 19 guests
