Headlights Relay for 1979 Fiat
I'm waiting on the headlights relay from Auto Ricambi. It is actually back ordered. Anyone who has installed this relay like to share your experience with it? Thanks.
Roberto
1970 Oldsmobile Cutlass Convertible
2005 Toyota ECHO
2007 Honda Pilot
2005 Toyota ECHO
2007 Honda Pilot
Re: Headlights Relay for 1979 Fiat
Great set up , only takes 1/2 hour to install .
Good to hear. Thank you.
Roberto
2005 Toyota ECHO
2007 Honda Pilot
2005 Toyota ECHO
2007 Honda Pilot
- Your car is a: 1977 Fiat 1800
Is that 30 minutes for an experienced mechanic, or 30 minutes for a novice? (For the record, I'm on the novice end of the spectrum.)
Ok for novice it will take 45mins. 10 mins to read instructions , 5 mins to scratch your head, 30 mins. hookup. All kidding aside it is very simple to hook up.
It's the Greg Smith version. Very user friendly and the gauge and length of the wires have been predetermined for perfect application in the Fiat's engine compartment.
Highly recommended, +++
- Your car is a: 1979 Spider 124
I wish I had found this website before I decided to figure out why the lights were so dim. I had 124s long ago so I knew they had dim lights. Turns out that with engine running I was only getting 9.5v to the headlamps (8.5v with engine off). After investigating the voltage loss at several points I found that every wire was dropping voltage, only getting 11.5v at the switch, loosing a bit more at the high beam switch, ect. One good thing was that the previous owner had put a monster battery cable in to the starter so I took power off the starter lug. By using the old headlight wiring to control some relays I added on the fender I am able to use the original light controls and now I'm seeing 12.5v at the headlights (engine off). Lights are now brighter than on my truck,, serious difference. And now with the headlights off the under voltage fuse box the interior lights are a tad brighter.
I see that you guys have found some kits that do the same thing. Where do the kits take their power from?
Update, I spoke with Matt at Vick Autosports about a different matter and asked him about the headlight relay kits they offer. He confirmed that taking the power off the starter lug is what they suggest.
If you have less than brilliant lights bypassing a lot of the voltage robbing old wires by installing one of these relay kits is the way to go.
I see three colored wires coming off the healights 3-prone connector. Black is ground. What are gray and green? Looking to ID the high and low beam wires to make my own relay harness.
Roberto
2005 Toyota ECHO
2007 Honda Pilot
2005 Toyota ECHO
2007 Honda Pilot
- So Cal Mark
- Your car is a: Fiat
it's much easier to take the 12v power directly from the alternator post
Mark Allison
- Contact:
Fuses 3 & 4 are the hi beam fuses Green/black wire is driver side wire and green is passenger side wire. Fuses 5 & 6 are lo beam with wires gray/black being drivers side and gray being passenger side wire. Relays are often mounted on the drivers side fender well and connected to the alternators output post through an inline fuse. One fuse is used for each relay. Usually both headlights are connected to one relay so one relay is the hi beam and one relay is the lo beam. Hope this helps.
For cars with the alternator on the passenger side of the car power is sometimes taken form the starter solenoid or the relays are mounted on the passenger side of the car.
- Patron 2019
- Your car is a: 1979 spyder 124
Hi
Installed headlight relays this weekend ,now have greatly improved lights . I Mcgyvered the assembly using parts from my junk box . Main power feed to the relays from the alternator, via a line fuse mounted with the relays in a small box in the engine bay . Feed to the relays by disconnecting the input to the head lamp fuses and adding jumpers to connect the relays. , Power to the lights from the relays , a second jumper to the input terminals of head lamp fuses at the fuse box .
Relays grounded at the ground connector near the driver's side head lamp
Total cost zero , total time a morning.
Maxdog
Maxdog
maxdog wrote:Hi
Maxdog
Just a detail, but wanted to check to be sure... that should say: "....disconnecting the input FROM the head lamp fuses..." Otherwise, the power leads to the lamps themselves might now be unprotected. Just checking.
- Contact:
There are lots of ways to add the relays in the headlight circuits. I am one who doesn't necessarily think there is a "best" way.
Everything one needs to add the relays is in the engine compartment. So one way is to unplug the headlight bucket for the side of the car you are physically installing the relays. Then use the cars wires from the fuses on that side for the power to control the relay. This way the control wires remain fused and protected. Just another thought and a little less work.
Spider, thank you. Your info works for me.
Roberto
2005 Toyota ECHO
2007 Honda Pilot
2005 Toyota ECHO
2007 Honda Pilot
Hey Maxdog, I have checked out some wiring diagrams online and there is this one suggesting the use of gauge 12 wires for the harness. What gauge did you use and what size inline fuses?
Roberto
2005 Toyota ECHO
2007 Honda Pilot
2005 Toyota ECHO
2007 Honda Pilot
Users browsing this forum: No registered users and 60 guests
