Remove 2 spring clips to remove the fan:
Remove small retaining clip to pop off fan blade:
Remove second clip and save small washer:
Bend back 3 tabs to dis-assemble motor:
Clean with electronics spray cleaner. Lube bushings (I used lithium grease). Re-assemble. No more squeaks!
Heater Fan Pictorial
- Your car is a: 1980 spider FI
Re: Heater Fan Pictorial
That is very helpful!
- 81SPIDERMATT
doing research I have found this thread .... I have checked the switch and have power and cleaned the toggles... guessing my problem lies at the motor end... my question is this .... how does one get to that motor ... where is it ? ... 81 spider ...thanks.... Matt
- bradartigue
Remove the center and radio consoles. The heater hangs from the bottom of the black assembly there in the middle. Use profanity to get it out - it helps.
1970 124 Spider
http://www.artigue.com/fiat
True on the profanity
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
81SPIDERMATT wrote:doing research I have found this thread .... I have checked the switch and have power and cleaned the toggles... guessing my problem lies at the motor end... my question is this .... how does one get to that motor ... where is it ? ... 81 spider ...thanks.... Matt
Look here: viewtopic.php?f=3&t=20987&st=0&sk=t&sd=a&start=45
Page 4 or 5 of that thread has pictures showing the location and removal of the fan box. Not hard to do.
- 81SPIDERMATT
wizard124 wrote:81SPIDERMATT wrote:doing research I have found this thread .... I have checked the switch and have power and cleaned the toggles... guessing my problem lies at the motor end... my question is this .... how does one get to that motor ... where is it ? ... 81 spider ...thanks.... Matt
Look here: http://www.fiatspider.com/f08/viewtopic ... a&start=45
thank you sir
- Your car is a: 1979 2000
Thanks for posting this Wizard124, it was a big help. Some more cleaning and then reassembling with a new heater core, valves, pipes, etc. I might leave a note/time capsule for the next person to find when this needs to be done in another 30 years.......
Users browsing this forum: No registered users and 18 guests
