Hello, would anybody care to look at the image below and tell me if I am just blind and not seeing the timing marks or is that protrusion supposed to be used in some way? Thanks in advance!
1980 FI Timing Marks
- Your car is a: 1980 Spider FI
Re: 1980 FI Timing Marks
My timing mark on my 83 is on the passenger side.
You can also remove #1 spark plug and put a screwdriver in the hole. Put the screwdriver to the highest point and you are at TDC.
Oh, is it the metal thing with the teeth???
Yes, now you need a timing light. 0-5-10 from the top.
Also, unplug the vacuum hose from the distributor and plug it.
Idle 850-900 RPM
Idle 850-900 RPM
ORFORD2004 wrote:Also, unplug the vacuum hose from the distributor and plug it.
Can you explain this in some detail as to why and what gain?
It was not in the book but if I remember properly, it was to be shure that the vacuum did not put some advance on your timing.
Users browsing this forum: No registered users and 40 guests
