Crankshaft pulley bolt
gjones1967
Your car is a: 1979 Spider
Postby gjones1967 » Sun Jan 14, 2018 7:20 pm
So I am presuming that the bolt that secures the crankshaft pulley to the shaft is a left hand thread. The reason I presume this is I broke the bolt off trying to remove it . Is it a major job to get the bolt removed? Sounds like a job for a shop in which case I may as well have them rebuild the engine.
Graeme Jones.
1978 Fiat Spider
1979 Fiat Spider
1986 Porsche 944
1976 MGB
2009 Honda Accord
2016 Toyota Tundra.
DRUMMOND
Re: Crankshaft pulley bolt
Postby DRUMMOND » Sun Jan 14, 2018 9:22 pm
Its a right hand thread. I am not sure if anyone can get that out, might be better with a replacement crankshaft? probably have to weld it equals a lot of heat/distortion
how did you manage to break that bolt??
gjones1967
Postby gjones1967 » Sun Jan 14, 2018 9:37 pm
I was undoing it to get the pulley off. Had an exhaust section over the socket to get sone leverage. It just broke.
Graeme Jones.
1978 Fiat Spider
1979 Fiat Spider
1986 Porsche 944
1976 MGB
2009 Honda Accord
2016 Toyota Tundra.
DRUMMOND
Postby DRUMMOND » Sun Jan 14, 2018 9:49 pm
I bet that was a surprise! :D
Air Impact driver is your best friend :)
gjones1967
Postby gjones1967 » Sun Jan 14, 2018 10:36 pm
Sure was a surprise I was convinced it was left hand afterwards.
Bought an impact gun last week then realised it was too small need the next size up....back to harbor freight!
Graeme Jones.
1978 Fiat Spider
1979 Fiat Spider
1986 Porsche 944
1976 MGB
2009 Honda Accord
2016 Toyota Tundra.
fiatfactory
Your car is a: 1970 128
Postby fiatfactory » Mon Jan 15, 2018 6:41 am
gjones1967
Postby gjones1967 » Mon Jan 15, 2018 7:39 am
It is the smaller one, 22mm I think. Engine is a 1980 FI.
Graeme Jones.
1978 Fiat Spider
1979 Fiat Spider
1986 Porsche 944
1976 MGB
2009 Honda Accord
2016 Toyota Tundra.
GeorgeT
Postby GeorgeT » Mon Jan 15, 2018 9:36 am
My '81 FI 2000 had a 38 mm (1/2") bolt. It's best to remove the radiator so you can more easily get to it.
gjones1967
Postby gjones1967 » Mon Jan 15, 2018 4:22 pm
It is out of the car on a stand. I'm annoyed at myself!
Graeme Jones.
1978 Fiat Spider
1979 Fiat Spider
1986 Porsche 944
1976 MGB
2009 Honda Accord
2016 Toyota Tundra.
gbraun
Your car is a: Fiat spider 1984 from california
Postby gbraun » Tue Jan 16, 2018 12:12 pm
When I tried to get it I was obliged to destroy it (drill in several points)...... impossible to unscrew it even with 2 meters extension on the 38 mm key !
Jimb
Your car is a: 1985.5 Volumex
Postby Jimb » Wed Jan 17, 2018 10:26 am
It sure sounds like you're tightening rather than loosening.
Return to “Engine and Tuning”
Users browsing this forum: No registered users and 33 guests
