Hi Everyone. I ordered a new Oil Pressure Gauge sensor for my spider, and I went to install it today and there is a copper wire coming out of the hole where the oil goes in. Before I contact the supplier, I just wanted to see if this is normal? The original one did not have this, nor have any others I have seen. Thanks in advance.
Spider OP Sensor by budzinsk, on Flickr
Oil Pressure Sensor Question
- Your car is a: 1984 Fiat Spider
- Your car is a: 1980 fiat spider auto
Re: Oil Pressure Sensor Question
budzinsk wrote:Hi Everyone. I ordered a new Oil Pressure Gauge sensor for my spider, and I went to install it today and there is a copper wire coming out of the hole where the oil goes in. Before I contact the supplier, I just wanted to see if this is normal? The original one did not have this, nor have any others I have seen. Thanks in advance.
the switches com with that wire. do not remove it.
1985 fiat spider auto
driven fiats since 1972
www.spiderroadster.com
Thanks. I did contact the supplier and it is correct to have the wire in there. Thank you!
Users browsing this forum: No registered users and 27 guests
