Hi,
I’m trying to get everything together to put a set of IDFs on my 1608. I have the waffle manifold and turtleback air cleaner.
Anyone know which crankcase vent hose works with this setup?
-G
Turtleback PCV Hose
- Your car is a: 1969 Fiat 124 Spider AS
Re: Turtleback PCV Hose
I think I just have some 3/8 hose for my 1438 with that manifold, but I can check in the morning if you want.
1969 Fiat 124 Spider AS0012768
- Your car is a: 1967 124
Sorry, I actually mean the breather hose. The one that goes from the oil separator on the block to under the turtleback.
I think that's bigger than 3/8 right?
Is the typical carb'd Fiat crankcase vent hose long enough to work?
-G
-G
- seabeelt
- Patron 2019
It should be long enough
- kmead
Yes its either 17 or 19mm ID, so 5/8 or 3/4 fuel grade hose, not coolant hose.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
I ended up using the same hose that fit the single carb setup and it works great!
Users browsing this forum: No registered users and 26 guests
