Hello all.
In process of the grand switch for my '79 2L. replacing the stock intake and 28/23 carb with a single plane manifold and 32/36
If I block the port from the exhaust at the head, is there any reason to block it on the intake side? any other passage as it goes through the head?
I would just pull the pipe off the exhaust manifold and plug it there, except as I was trying to get the large fitting out, it turned a few times, then just seized.
thanks
Geo
EGR
- Your car is a: 1979 Spider
Re: EGR
Well, you got it to turn... Mine wouldn't budge. This is apparently very difficult to remove, esp with the manifold still on the engine. I don't think it matters where it's plugged, with the possible exception of imperceptably better exhaust flow if you can get the pipe off the manifold. I spent too much time researching the best solution then plugged it on the intake side. It's also possible to cut a small plate to block the pipe on the exhaust side at the gasket. I recall some have cut the pipe and plugged that.
'79 Spider
'15 Tesla Model S85D
'14 Santa Fe
'17 Civic
'14 Santa Fe
'17 Civic
- Texafornian
Re: EGR
I sprayed mine with PB Blaster and let it sit a couple of days, then was able to turn it. If you use a 10mm hex wrench you should be able to get it to move. I removed it and am liking the cleaner look. Eventually I will need to source a new cam cover without the pass-through. I was in the process of diagnosing some tuning issues with my carb and can't see how leaving it there and unplugged would help anything. Good luck!
Daniel
Users browsing this forum: No registered users and 10 guests
